Umm help need for CASE !!!
4 Apr 2010
Um hey there this is my first time posting in these forums :D
Can you suggest me a good case for water cooling and EATX motherboard config ....
I was looking at the Corsair Obsidian 700D , the Coolermaster ATCS 840 , the Cosmos S :P... I want this case to be able to house a 360 RAD at least ...
Peace out thanks :D
I would go for the ATCS 840. Although that's just personal preference, I like the look of it and know from experience that coolermaster cases and watercooling go hand in hand :)
umm yeah I like the inside of those cases all black and the cable management holes are awesome .. but i like the look of the cosmos s from the outside
Well I can tell you now. Both of those cases have specific mounting holes in the top for a 120.3 rad. Both were built with watercooling in mind, so it doesn't matter too much.
One warning though, I've heard that the Cosmos S side fan can get a bit noisy/rattly. Depends if that bothers you or not.
Its arriving on Friday :D
I have to spray paint it .... all black in/out...
now can you help me in the watercooling side pls !
I am thinking of a
-Black Ice SR-1 360 Rad with Phobya G-Silent Fans
-Laing DDC Ultra + pump with phobya aftermarket top or the EK v2 ( dont know which one )
-Umm cpu waterblock ,a toss between the EK HF ( normal copper one or the EK HF full gold )
-Reservoir haven't decided yet , I waiting for the case to know the exact dimensions so I can choose a res...
-Fittings ... Bitspower 1/2'' barbs , am considering compression fittings but I am a newbie for those...
-Tubing Primochill PrimoFlex Pro LRT 7/16'' ID ( snug fit with 1/2'' barbs )
-Fluid : Primochill ICE clear no uv's and stuff...
Tell me what you think and if I forgot to list something...
The HAF 932, the power supply can go at the bottom or top, the plate which covers the empty space has rubber tube holes if you want to run an external watercooling system, the top is deigined for a 240mm radiator and can support E-ATX. and its also very spacious and rather large, also it retails for around 100 Pounds so a bit cheaper then other ones mentioned :)
I said that i bought the case lool but anyway thanks for that suggestion .... in my case I dont like the look of the Huge As **** 932 :D ... Comos S ordered should be here very soon ... :P
Water Cooling section :
I am thinking of a
