I have a Nilfisk. I'll see if they do a similar attachment.
stick a full bottle of bleech in it late at night when people aren't likely to be unloading water down the drain
actual bleech, don't get that "better than bleech" gel crap it doesn't even melt turd stains from the side of a bowl.
@Merlin5 seems they do. £32 on amazon
If you use drain rods they don't necessarily have to reach the blockage themselves. The circular rubber attachment is designed so you can use it in a similar way to a plunger. It forms a seal in the bit of pipe you can get at, and you are using the pneumatics of the water that you can get at to cause a very powerful force against the blockage further down the pipe to try to force it through.
Search for - Nilfisk Drain & Tube Cleaner 8M
I've also got these - https://www.screwfix.ie/p/bailey-19mm-blue-brass-jointed-drain-rod-set-9-14m/79897
Which are excellent. As bazzabear says using the attachments to build pressure to push away the blockage is what you're working to do. They were a lot cheaper when I purchased them and I'm not sure what the difference between the black and blue version is.
Regarding the water company, in general if you share a waste connection then anything under ground is for them to deal with. I'm not sure if that applies to flats though, best check with them.
I have that one. Works well, although be careful to keep it well under the water line or you will end up with the drain deposits all over you.I think this is the correct Nilfisk Drain & Tube Cleaner?
https://www.amazon.co.uk/Nilfisk-Cl...ocphy=1006886&hvtargid=pla-416425218440&psc=1
This isn't terribly relevant, but you've reminded me of a story. I once had the gutter overflowing at my old house, so I was investigating what was going on, and realised the bottom of the downpipe was completely blocked with something. (It was badly designed, with a flat end which was only a few mm above the grid to the drain.)
I failed to make some pretty obvious deductions at this point, and just set to with a screwdriver trying to wiggle out what was blocking the downpipe. It turned out to be a few stones, with an empty pill blister pack lying on top of them.
Of course, as soon as the pack was dislodged, suddenly I had a 20 foot tall pillar of water exerting pressure on a very small opening, and I got absolutely deluged with stinky, stagnant gutter water. It was such a surprise to me when this suddenly erupted that I gave out a little scream (well, manly yell obviously) so I got some of it in my mouth too.
Something like this might work? Rothenberger Pipe & Drain Cleaning Coil 1.32m | Drain Cleaning Tools | Screwfix.com
I don't think it's designed for outside though.
If you get drain rods then make sure you read the instructions on which way to rotate them, if you turn the wrong way you could undo the rods while they're in the drain and then you'll have a proper blockage!
That drain is more than likely a trap ( it looks the same as mine) so you would not get rods down there, the nilfisk drain attachment is a better option
