Under volting
17 Jul 2008
Just finished a new build, 3570k in a z77 d3h with 4gb of Kingston hyperx Genesis @ 1600 - 1.65v. Cpu cooler thermalright macho 120 in a z9 plus case. Stock volts for cpu were 1.045v. I have been following the oc guide by tiny tom logan for 1155. So far I have got to cpu @ 1.015v turbo boost 3.8ghz 30mins stable occt linpack fixed voltage with llc set to extreme, performance enhance normal, dram timing selectable (quick). Ram timings 9, 9, 9, 27 @ 1.65v. Just want to run at stock speeds first at lowest volts before overclocking later, how much longer should I run occt for. Is 1 hour long enough ? All other settings are from optimised defaults which I started with. First time ocing self build. Pc is I have to add for my son, mine is in sig below built by Overclockers thought I have ago myself this time. Forgot to say highest temp so far 49, 56, 53, 51. after 30mins. idle (26, 27, 25, 20) case temp 22º.
is that ram rated at 1.65v for 1600mhz? usually 1.5 or 1.55v dram is enough
to undervolt the cpu you have to set cpu voltage to normal and use a - dvid/offset so maybe -0.005v and increase if needed -0.010v and so on ect
I tend to do 5 runs of intel burn test on standard or high,then test in games ect,i wouldn't run the max stress test in intel burn test as it might get to hot for your cpu
Ram rated at 1333 @ 1.5v or 1600 @ 1.65v xmp profile is 1600 @ 1.65, was part of a triple channel kit I had spare from my i7 930 build. Open to suggestions as I'm only going by the guy's method online as he doesn't use any dvid offset. Is occt linpack too strong a test ? Should I be using prime instead ? As for to hot I thought temps are nothing to worry about until you reach 80º or am I wrong ? If his methods are wrong then should I be doing something else ? All advice appreciated.
You might see better results with ram designed for z77 and 1.5/1.55v rated
Dvid is the only way to undervolt the CPU voltage or add voltage if overclocked and still want the CPU to downclock itself at idle
I'm a little confused, so far the cpu has down clocked an run at fixed set voltage of 1.015v fine and when stressed voltage has increased because of the llc set to extreme but not by a huge margin. All this without using any dvid offset. I assume his methods are different. Ram is no good then ?
Ram might be fine,but if its unstable and crashes its probably because its x58 memory
Far as I know it won't downclock in auto or fixed CPU voltage,only in dvid
Are you looking in CPU-z at idle and load speed/voltages? It should use less than 1v at idle and full voltage if stressed
Oh and you won't need extreme llc at stock clocks imo,set it to low
From memory cpuz at idle clocks showed 1.02v @ 1600 MHZ and @ 3.8GHZ showed 1.03 or 1.044 I think, It cannot use any less as I fixed the voltage. I can check the logs created by occt any way. As for the ram was just trying to save some money, wanted 8gb really. Will look out for an 8gb kit on daily deals. Thanks for your advice so far. Could the offset you mention be on auto ? I will check the bios next time it's on.
Try that ram for now,it might be fine,id only change it if you run into issues
Dvid won't be enabled until you change CPU voltage from auto or fixed to normal
And @1.02v idle it isn't downclocking in voltages,it should go as low as 0.8/0.9v if you use dvid and a negative amount
Many thanks, I'll check tomorrow and take some screenies and post. Will be overclocking but not just yet, want to just be stable to give my son for now. Have to add a couple of older hdd's and a 8800gt from old rig until funds allow for gpu upgrade. Oh I also have a corsair vengeance kit of 3 x 2gb kit rated at 1600 @ 1.5v timings 8, 8, 8, 24 if's that's any better.
Took a screenie, have now set a fixed voltage of 1.005v still have llc set to extreme. During a 30mins occt linpack run the voltage went up to 1.032v @ 3.8GHZ. The picture was taken just befor start. So is this not still down clocking and lowering volts ?
Not with a fixed vcore,you have to set it to normal and use a lower llc and a dvid voltage
EDIT: I see you pic now,yes it seems to be downclocking but you sure you've used a set/fixed voltage? it shouldn't downclock with a fixed voltage
its hard to tell because you've only set a 1.05v voltage and llc will bump it up to 1.032 at load,
heres mine using an offset/dvid voltage
load
idle
Yes voltage is definitely fixed, I typed it in manually. At auto it was 1.045v, in box next to cpu vcore typed new vcore and hit enter was going down to amount shown even when fixed vcore was higher. Dvid is on auto at present. Couldn't find manual setting in bios it's either auto or a fixed amount, unless I'm missing something. Which key changes auto to manual ?
didn't you see normal? in the list of volatges?
seems to be working though but you could tune it closer if you can get dvid working
Selected box with mouse and just typed in value instead of auto. System off now, is it arrow keys or page up down keys sorry didn't see it first time around. Will try again tomorrow. Just trying to find the lowest voltage for cpu which will allow boot into windows and then turbo boost upto 3.8ghz . Is it worth going any lower ?
here
its up to you,the lower the voltage the less cpu temp,its the + and - to cycle through the voltages
remember its + dvid to add that amount to load cpu voltage
or - dvid to take off that amount from load cpu voltage
idk what cooler you have,get a good one and oc it,if it can do 4.5ghz with 1.2v or there abouts you have a decent chip imo
