Would putting down a good thick carpet and underlay make much of a difference?. The carpet thats down in my bedroom at the moment is very thin and the underlay is the cheapest rubber stuff you can get. I was planning on putting a thin membrane down (fiber that stops the underlay sticking to the floor boards) then this really good quality rubber underlay. The underlay is called hallmark, i got a small sample and its very heavy and thick and feels good quality. Then a thick piled carpet over the top. I was hoping that would make a difference but looking at all the work you did i don't think it'll do much.
Was the rock wool dear to buy?, also which would be best for under floor boards, the 50mm denser stuff or the 100mm?.
I was hoping not to take all the floorboards up as that would be a massive job. My plan was to just tape all the floorboard joins with ducktape or aluminium tape and seal any big gaps with sound dampening sealant.
