@Surfer those temperatures look fine now. Although, you need to disable Vsync when you are testing, that's the reason for the limit to 80-ish percent.
Using a program to cap FPS also reduces temps by a lot by reducing the amount of work the GPU has to do. I usually set mine to 75 since I stop seeing a difference after that.
It could be that particular game. It could be a CPU bottleneck in that benchmark (see if the CPU hits 100% load when the GPU is sitting relatively low load).
Run a Firestrike test and check for 99% usage.
