Undervolting Strix 3090 - Need opinion on results
14 Jul 2017
Hi,
I wanted to share my results with undervolting my GPU and ask for advices.
I have made this voltage curve : https://www.casimages.com/i/201111101728556514.png.html
I maxed out the power limit, haven't touched anything else.
Here's the results on timespy : https://www.3dmark.com/spy/15188725
GPuZ capture : https://www.casimages.com/i/201111101738196296.png.html
to compare, here are the results with the "factory oc profile" : https://www.3dmark.com/spy/15188951
https://www.casimages.com/i/201111101712715273.png.html
However i was just concerned about the perfcap reason, i got pwr and pwr thrm with the curve for instance. could it be an issue?
the results are better with the undervolt even if the card doest not clock as high, 1965vs2010
temps are almost 10c lower.
I used the bench in assassin's creed valhala
Stock oC
Bench https://www.casimages.com/i/201111103314455549.png.html
Gpuz https://www.casimages.com/i/201111103314208980.png.html
Curve
Benchhttps://www.casimages.com/i/201111103330517889.png.html
Gpuz https://www.casimages.com/i/201111103330345596.png.html
Max fps are lower with the curve but the average remains the same.
Also, no issue of perfcam with the curve but there are some with the stock voltage
Also, temps are WAY Lower with the curve !
Do you think I can call it a day and keep it that way or could it be better? Am i way below normal scores for this card with UV?
All is stable, temps are fine, average 58c in game in AC vallhala for instance.
However i feel like restraining a bit the power of the gpu.
How could i overclock it with the voltage curve without rising the temps too much? at with voltage the temperature will be too warm do you think? i'd like to be able to reach at least 2080Mhz for instance like I was able to with the standard OC profile but I don't know at all what voltage I should safely target for that.
Thanks for the help !
No it's not a troll post, it's a legit question. I just want to have an opinion of which voltage I should target on the curve to reach 2080Mhz for instance without setting an offset that usually put too much voltage and heat
Well I believe depending on the card you have, the card is locked at power draw anyway, unless you want to start using custom bios, or shunt modding your gpu to allow more power.
The reason I thought your post was trolling was that you haven't mentioned your fan curve, are you ok with ramping them up to 100% to maximise cooling to prevent thermal throttling.
Everyone's card will behave a little bit different in regards to voltages, depends if you got lucky with your silicon, but I would ramp your fans up to 100% and then see if your temps drop
Well right now the fan curve isn't that agressive with the undervolt the card stays very cool, 60c max in game @ 1965mhz.
but since i'm kinda new on the voltage curve OC, usually i just add some offset in memory core and vram, i wanted to know what would be safe to do.
For instance this : https://zupimages.net/viewer.php?id=20/46/0edp.png
0.975 @ 2070 mhz, could it be an ok one.? Haven't benched it yet
Have you tried asking in the Rtx 3090's Owner thread, they may be able to help you out better.
But with all overclocking it's a case of trial and error. writing down all the settings and numbers of each pass until you hit a fail.
ah no i haven't posted but that kind of topic usually .. I have issue to get answers since its a bit of a mess lol.
i've just tried this curve on my Strix 3090,
https://www.3dmark.com/compare/spy/15304171/spy/15274495
The score is not that much better than with 0.900 @ 1965hz and i got some perfcap reason pwr + pwr therm in gpu z even with maxed power limit
https://zupimages.net/viewer.php?id=20/46/qg3e.png
What does it mean for my card and overclock?
Means your card has hit the limit. you're probably locked due to Power Limit you have on your card, look up about custom power bios for rtx 3090, but tbh I wouldn't mess around with that unless you are very comfortable with the possibility of bricking your card. If you google it there are a bunch of guides and studies done on overclocking the 3090's. Gamers Nexus would be a good place to start as they have an actual video of them overclocking a rtx 3090
Hi
i've undervolted my Strix 3090 to 0.850 @ 1905 but i find my temps quite hot even with it
while playing some games like days gone, i have around 70c on core and 86c on memory
I game at 3840x1600, i've also put some heatsink and a fan on the backplate to cool vrm but not sure if it does something to be honest
I don't want to go on water for now or change thermal pads for warranty issues
Are thos ok temps for this gpu? I'm quite concerned by temps
If i go lower like 1850 for 0.8 will I lose a lot of performances?
Hi
If you using the performance fan curve and are getting 70c with just 0.850v then something is wrong. Maybe your case doesn't have good airflow
Cause iirc in my own testing, my 3090 Strix at 0.850v would only pull 250w and run under 60c. Well now that my card is on water, the same settings gets temp between 35c and 38c
Well i have
Ek aio on front with 6 lian li unifan push pull
3x120 lian li on top exhaust
1 on the back exhaust
P600s case
I've also put heatsinks and a little fan on tje backplate
The 70c is just in some games. In valhalla for instance it's more around 60, days gone for instance seems to have a big hit on gpu temps
I'd emphasise monitoring the card for throttling during benchmarking, with the amount it throttles as an important one of the numbers you mention. It's not unusual for power draw to be the limiting factor in a graphics card (even with power limit increased) and then increasing the clocks past a certain level is worse (but still OK) in temps and stability but does nothing for performance because it just power throttles more.
