Uni network question
4 Mar 2008
Guildford
Hi all,
I have my desktop and laptop at uni. My desktop is connected to the uni network via ethernet (through an unmanaged HP switch in my room) which works fine.
My laptop also connects to the uni network (either over the wireless or through the switch, when I connect it.)
Now I have a netgear router up here and what I was hoping to set up is my own wireless network which would enable me to stream movies from my desktop to my laptop, while still having my desktop connected to the uni network. (ie I would choose to connect my laptop to my wireless network and be able to see folders on my pc and stream over it.)
Is it possible to do this while also being connected to the uni network. I have 2 ethernet ports on my pc so that would not be an issue.
Something like:
Uni Network --> desktop --> Router > *Wireless* > Laptop/phone/tablet
if so how would I go about setting this up?
Cheers
Ali
Could you not buy a cheap pci-e/usb wifi adapter for your desktop and use Windows internet connection sharing to achieve this?
I have a USB wifi card for my desktop, but not sure how that helps? I don't want to connect to the uni network over Wifi as there are 20 people using the same access point and it tends to slow down quite a lot
Why not connect the router to the switch? I'm assuming the router doesn't have a WAN port, so you will need to disable DHCP on it first otherwise it will interfere with the university nerwork. And then connect your PC and laptop to the router however you like. Of course, this is assuming the university's IT policy allows you to have more than one device active.
