Unigine Superposition Benchmark.
A quick run with my 1070 :) not for the scoreboard.
Will be testing my overclocked 1080 Ti tomorrow as well as my twins 980 Ti:)
1080p though and it takes a 1080 Ti to comfortably get more than 30fps!!
Nice benchmark actually, seems a lot less strenuous and picky than Heaven/Valley can be.
i7-6700k 5.0ghz on air
Titan XP @2139/2812 on water
5oSLp5U0zgm5seMyp1albSlXE008VadWI0uxQtGRDAs1i_L8XbXmp-yDpomTecORecodI7zuIG0i9huK3zaVKNpwF-La3UeV8pSbLQkQ725AMfNEtpIqmfaHetn7Mww_LgB2u0x7kH1N5qEY2M6SNGoAhj6WGN-qW5gxZa7o0shtjfaSm3-lgvHrNsuDiuHucVevEOUZeDv2Q8Hc1Xx-IjwIQRc4Gxeu6ipKFaOZvn8eovl2ZRVxBDmNWPt17Maff7tFYH7hpFFsAD2aCs0G5U9QvQxyuQ1pJOUIqiyroqZRNinfcAkWwjYqyGu-af9e8rX-aG0kSMLhOP_sEyrShgGsT43suLOS0Us1d6P6-JP5F-MOoFUHF0szGd3fy2CGX2dfwU7rJiEUfQJ96Ez5D48G0o8USWU45a9wTep0Fyr4CDozTls8z0yM8V5Wsx7N3dX8vxs4VP0SFf1eU4bpD9Pph9HyEZ1GXWE8TBE0l_3NdMpHJ1bLK2U-J6IPWt9sr9_8uxpl72Tcdu_QmK-H3Ll_EB6wiwUYBtK1atstkd12esj2nhSk0kD62SnCi4LSjW8X0FImX5tXkhb_8IlbYnw-4PT7j9FcqKpM-yqaU6KR8wA6PKnx6emtgDdYP66cIhCdhigzIalYN24uZDN-jWZ24Vmf6PHHZgQyBAS_f9o=w1920-no
JR
For the scoreboards can you use these settings please.
Any resolution can be used.
Shaders = Extreme.
Textures = High.
DOF = Enabled.
Motion Blur = Enabled.
When you post your results please use the format below.
Pascal Titan @1873/2502
6950X @4.0
Drivers 381.65
I just did a run at my native 3440x1440 and my 4790k and stock clock Fury pro managed a respectable average result of 10.9 fps. derp!
Come on Vega...
thanks Scotty. Apparently posting a pic is too advanced for me:)
is SLI working for anyone else? Only using one card for me.
All resolutions must use the settings I posed above.
1080p Extreme preset is exactly the same settings right?
Note to everyone, if you save the results page and part of it is off screen then it just comes out black :D, looks like i'm doing more runs tomorrow.
JR
JR
I Think there is a difference. The 1440p preset definitely runs smoother than the above settings.
I think he means the settings Kapp is using when at 1080p, which are the exact same as the 1080p Extreme preset. Both max out all the available options.
