- 11 Jun 2021
- Kent
Hi
So I’ve been building rigs for years. I recently upgraded my 3070 to a palit 3080 ti and have a unique problem. The drivers won’t install.
So I always like to do a fresh install with a new gpu, using ddu to remove previous drivers, and this new palit 3080 ti just hangs and errors when attempting to install drivers.
I’ve tried everything, making sure windows is up to date, doing it as an admin, disabling windows live protection, safe mode, using device manager, tried installing drivers with the 3080 ti across 4 different systems, everything.
When I put the 3070 back in the drivers install perfectly fine, and the weird thing is when I put the 3080 ti back into the machine after using the 3070 to install the drivers, the card appears to function fine. If I uninstall drivers and attempt to do it install them again with the 3080 ti installed they just didn’t install, again trying everything including trying it on 4 different rigs.
Ive had bad gpus before this the first time this has happened.
Just wondering if anyone else has had a bad gpu relating to a software problem with the card instead of a hardware problem?
