Unique 3080 ti problem?
Delete the competitor name before mods see it, its not allowed on here. Saves you getting suspended mate.
They can be abit of a pain in the arse, i've had some rough dealings with them. Good idea though, if they do argue you can just flash the bios, there's no loss to you either way i suppose provided the flash fixes the issue.
Oh whoops didn’t realise that was a problem. I’ll remove it
Another thing to check is if your PCIE connection is good, some riser cables can ruin your day (try without one).
Have a look in CPU-Z and check you are getting Gen3/4 @ x16 speed. I've seen dodgy connections causing it to fall back to x4 speed and causing weirdness.
I don’t use a riser cable. I checked gpuz, shows as gen 4 x16 as expected once it’s in a system that has nvidia drivers already installed
