Mattus said:I always thought it was updated at the end of every frame/percent of the WU?
Current Work Unit
Download time: July 26 07:04:34
Due time: September 16 07:04:34
Progress: 98% [|||||||||_]
For the cores that deal in percentages, it is every percent. With the cores that deal in frames, it is however many frames make up a percent before an update is made.Mattus said:I always thought it was updated at the end of every frame/percent of the WU?
FAHlog will continue to grow as long until the client is restarted - when the client is restarted it checks the size of the log file and if it's over 50K it will save the information in FAHlog-prev and start freshRobOC said:That worked a treat. FAHlog is a bit bigger to upload but not by much. Good stuff, it'll do for my purposes.ta!
