So my question to OcUK Grads, when you chose you uni course, did you pick it on a subject you enjoyed? Did you look at your career path afterwards? Or did you do something you thought you'd have a lot of free time on and be with a load of girls?
KaHn
No, no, no, no and no. Universities need to adhere to a minimum standard. The standard of University courses varies immensely from one institution to the next. The cynical side of me thinks that all Universities offer some slightly watered down courses at post graduate level that act as cash cows.Isn't uni a lot easier...? Well I found it so yes, because I di maths, physics and chemistry at A-Level, my masters was easier than A-Level as well (although there was a lot more time spent on working). Just depends on what you did at A-Level and how hard you found it. What's a "top university"? Considering before you answer I'd like to point out any accredited course (like most in the engineering world and within a lot of other areas) should be of the same difficulty, that's the point of accredation and external examining.A straw poll of some of my masters colleagues recently just showed this... I'll agree with the latter though, but it's all about the type of course more than the university...
The CTA qualification is the devils work, so I fear I will not like it.
And while I'm ranting: I also firmly believe that there are way too many PhD students. It seems to be the new "I'll do an MSc" or simiilar, and Universities are keen to fill up as many places as possible, else their funding might get cut.
I find it very difficult to believe that engineering is special, in this respect. I'm not an engineer, but know a few academics that are. I'll see if I can get some input from them.Amp34 is right about engineering degrees though, they're often very carefully accredited to make sure the standard is consistent and so are usually fairly similar.
Will agree about other degrees though.
I think those courses can still be significantly different, though.
Aerospace engineering, at Sheffield and Sheffield Hallam, as an example,
For Sheffield AAA is required, for Hallam 300 UCAS points is required (so BBB, or lower, if more than three are added up).
I presume they're both accredited by the relevant bodies, but I'd wager a hefty sum that the uni students are taught better than the Hallam students. Both courses will meet a standard, but that's not the end of a story.
It'll be the same with other courses which require accreditation/regulation - qualifying law degrees need to be accredited by the SRA, which most are, but a Cambridge law student's going to be better than a student from a random ex-poly.
I'd double check that. Not all uni courses are accredited. Also kahn what engineering degree did you do/how did you find getting a job at the end? Do you use much of what you learned at uni?
Currently I'm studying mechanical engineering at Glasgow (though need to pull my grades up!)
).Wrong. There are so many mature and retired students not learning a degree for the purpose of getting a better job.
