UNIX Blade 1000/2000
6 Jan 2006
Newcastle
Im using a unix box at uni my job at the minute is to reinstall Solaris, since the original O/S just hangs after configuring the network adapter, so I got in a cd drive and tried to reinstall however it detects the cd drive but "cant open the boot drive" any ideas (burnd 2 copies ofthe disk 1 of solaris 10 twice once at normal speed and 2nd time at a lower speed to see if the disc or image was at fault also tried seveal different header options on the cd drive to see if it was that no luck there any ideas ?:confused::eek::(
Im not familiar with a unix blade 1000/2000, is it sun hardware or x86? If its sparc based then a solaris jet/jumpstart server is the way to go to install the os, a virtual machine is what I use to build mine. If its x86 based then you can still jump it but dhcp needs a bit of messing around with to make it work.
