unknown problem plz help
20 Aug 2004
Bournemouth
ok asus motherboard. was working fine 2 weeks back. just plugged it in (all correectly) and it does beeep beep beep, which according to reliable sources is a problem with graphics. Its an sli mobo, so I have tried the gfx card in both slots, and another card too, also in both slots. Same beeping. reset bios. Theres no onboard video. Suggestions?
well it was ram, I removed some and it worked fine. But since then it blue screened occasioanlly the last few days. So I replaced the ram with a shiney new 4gb and the damn machine wont boot again. the same beeeeep beep beep. Tried the new ram in every slot, each stick one at a time, and now they are sitting in my main pc proving they work fine. So it looks like its back to a mobo problem
putting the previous ram back in doesnt help though, and it wor4ked fine on the new ram for half hour or so before problems
