I need to remove a drive from a system that can't be switched off and was just wondering how safe this is.
I use HotSwap! quite often when I'm disconnecting/connecting drives via an eSATA caddy, so I figure I can just "eject" the secondary SATA drive and then unplug the internal molex power connector? The only difference I can see, is that instead of having a convenient power button on the caddy, in this instance i'd be pulling out the power directly.
It's an Asus P5N7A-VM if that matters!
Thanks!
Thanks!
