UnRaid running plex and HA
23 Jan 2005
Hi so finally looking to jump from truenas to unraid as i will only be looking to have plex and home assistant running on it for the time being, so anyone running these apps report any problems ?
Thanks
It's pretty easy, I followed this guide
The only issue I had with running a VM was trying to get a USB Zigbee stick working, I tried a couple but never got it going.
In the end I bought a Zigbee PoE device from a guy in the US
Thanks I will have look when I get home
Unraid is pretty much made for this kind of use case. I run Plex on it in docker. I run HA on a separate machine with ESXi though, purely so that if/when I ever mess with the Unraid box I'm not messing with my router and HA.
What hardware do you run HA on, is it HAOS on top of ESXi?
It's on a Dell Optiplex 5050, can't remember full specs now but I believe it's an i5 7500, 16GB ram. Running ESXi as the hypervisor, Home Assistant provide a virtual machine image premade on their website.
You can run Home Assistant on unraid with socket pretty easily though.
I run both HA and plex on unraid with docker, also run a ZigbeeUSB on the HA docker container. You can install both from the unraid app store, should get you most of the way.
Thanks all looks like i will make the jump i just need to find out about my hardware so will start a new thread.
Thanks
