"unrecoverable sector count"
27 Jul 2009
Hello,
I have a 1.5TB AV-GP Western Digital that I have run through Speedfan and the SMART test is telling me that there is a problem with "unrecoverable sector count".
My other two disks (Samsung F4s) are coming out as fine and I have tried using the AV-GP by putting some none vital data on it and to be honest it seems fine.
1. What is an unrecoverable sector count?
2. Is it serious and/or correctable?
3. Could Speedfan be wrong? What other programs could I use to double check the fault?
Thanks
A
Thanks for that - I downloaded that program and used it to completely erase the drive using the WRITE ZEROS TO DRIVE OPTION.
I then initialised/formatted the drive back to NTFS using Windows 7.
I then did a full check disk in Windows 7 with both options ticked (no problems found).
I then did a QUICK TEST with Lifeguard again and it reported no problems.
Given that both WD's program and Windows itself are reporting no problems, should I assume that the disk is fine?
If so, what is it about Speedfan that keeps reporting 0 fitness with this drive - it is still reporting this, despite the above.
Thanks
