What'cha talking about Willis?
At no point have I mentioned the government being a building owner.
Well you referenced austerity being a factor - I joined them together
Anyhow, it is unfortunate for the owners - the costs are crazy.
Would the bank even repossess in these circumstances? If the asset is essentially worth £0 (no one is going to buy it), and by repossessing surely they would become liable for the costs?
Aye iirc there were several similar instances at the time, another one was the post WW2 prefabs that were tried near Milton Keynes (from memory) that were basically rows of bungalows made out of a cardboard based material and had to be put out of use in a fairly major hurry after what should have been a minor fire went through a block in a matter of minutes.
the problem is a lot of these buildings have people who bought their flat with a leasehold, if they leave they're without a home and still on the hook for the mortgage, but because they're leasehold they can't refuse to pay things like the "maintenance" fees or shared costs for the fire patrols.
It's why some of the people are ending up letting their houses be repossessed, they can't afford to pay the mortgage and the other fees so unfortunately for some the only option is to write off probably the most expensive thing they've ever bought, and potentially go bankrupt in the process.
Not sure the bank would want to be lumbered with a load of flats which are worth nothing and they can't sell.
I suspect it's a long play by the banks? They know that in the long run, if they have lots and lots and lots of properties that are sitting empty because of the cladding issue, the government may well bail them out with the costs of the cladding work to ensure those properties get made available again.Yeah, this is what I was wondering - you'd think it would be in their best interest to "pause" the mortgages or something, to give the owners a chance to pay for the repairs. Otherwise they could potentially end up stuck with tens (hundreds?) of empty flats that nobody wants, along with also having to pay for the repairs themselves?
I certainly don't think the government (taxpayer) should pay - the costs should fall on the owners.
I think the government and the industry need to set up some kind of compensation fund to help out these poor leaseholders. And the government should go after the manufacturers of the cladding and the architects who specified them with full force. Get money from them and put some people in jail for it.
of course each leaseholder and freeholder of the properties must share the burden. But 20k falling on the leaseholder alone with nothing for the freeholder is scandalous as the freeholder is most likely the people who developed the property and made commercial decision at the tim to go with cheap as opposed to something that cost £10/m2 more that is safe.
Government spent billions bailing out banks and airlines, they should setup a fund to help real people. The money can be tied to a portion of the equity of the property so that when the leaseholder sells the property then tax payer gets their money back.
i think you might be right, the red tape will be horrendous.Though a fund will never end up being used. Look at Windrush, almost nothing of that has been handed out and some of the people have died since.
Same with Gov housing upgrade grants, because it's too complex for builders to get involved and so not worth the time. Looks nice for the elections though.
i think the post was arguing that if tax payer picks up the full bill, then all it benefits are effectively property owners.Why? Imagine you've just spent £300k on a new build. Turns out the plasterboard walls are full of asbestos, but this wasn't flagged by the builders or in any surveys because the manufacturers falsified the materials spec sheet. Do you think you should be liable to have it all safely removed and replaced? What's the difference here?
Particularly since it's often people who are unable to afford a house... and then they get this bull****!!!
A lot of these affected places fall into starter home category and came with H2B incentives and/or low deposit options.Are you referring to renters?
It's on a par with some of the tower blocks built in the 50's and 60's where they found that rubbish had been used to fill gaps in the structure (iirc discovered after a gas explosion that should have been a relatively minor thing caused an entire section of one to collapse).
