Unstable OC Help
I have the silver arrow and the noctua d14
But they are big coolers and you'd need low profile memory or it will hit the heatsink
The k2 mount doom is also a good cooler with better clearance for memory
Dropped the multiplier down to 43, but kept vcore normal with +0.020 DVID.
Running a Prime 95 blend test over night to see what that throws up.
CPU-Z is reporting 1.296v on load and temps are around 65.
Prime 95 ran for 8.5 hours with no issues, especially no WHEA errors and hit maximum temps of 75 degrees.
Looks like 4.3Ghz is where my chip is going to be stable, so I'm happy with that. I'll re-run the test with a slightly lower dvid to try and find the least voltage I need and I think it would be wise to upgrade the cooler.
