Hi guys I have been running my system stable for a long time on these settings
Clock ratio 20X
BLCK 200
QPI Link Speed X36
Uncore Frequency X13 (2600mhz)
Memory timings (standard) 8 8 8 24 command rate 1
1200 MHZ (memory)
Voltage 1.5v (memory)
CPU vcore 1.26V
QPI/VTT voltage 1.335v
HOWEVER people with a sharp eye might have spotted that I'm running my memory lower than the standard setting 1600MHZ... This is where the problems occur if I increase my memory speed...
I change these settings
8X 1600mhz (ram)
Voltage 1.660 v (ram)
Uncore frequency 17x (3400mhz)
EVERYTHING els kept the same however when booting into windows and stress testing on maximum via Intel Burn Test v2.3 it shows an error on the second result...
My specs are in my link under my sig.... Are there any settings which are wrong??? Anything I need to change to make my memory stable at 1600mhz
Anything obviously wrong I've done that's staring me in my face???
Also anyone with the same motherboard as me what setting did you use to get the memory stable at standard speed of 1600mhz....
Thank you
Clock ratio 20X
BLCK 200
QPI Link Speed X36
1200 MHZ (memory)
CPU vcore 1.26V
8X 1600mhz (ram)
Thank you
