I often hear people say they're "coming down" to go somewhere, I was wondering what they mean when they say this.
Do they mean coming down in a literal geographic sense, moving down on the map to get to a location?
But some people seem to use "coming down" regardless of the direction they're moving in.
You do definetely get the literal geographic people I think.
What about "coming up"? Would you say "coming up" to say you had moved in a upwards geographical direction from a location to get to a destination.
Would you go as far as to use "coming up" regardless of which direction you had moved in?
What about "coming across?" I think this is usually reserved for overseas trips, but possibly could be used when having moved in a general horizontal direction from a location to a destination? Or not.
Help me out here, lets take the EXTREME example - north pole to the south pole.
Would you say "coming down", "coming up" or "coming across" with the knowledge that you could move down, up or across geographically the same distance for each.
Or would you use "coming down" again regardless of which direction you had moved in.
Thanks guys, really interested to hear your responses.
