okay then not so long ago upgraded my 512mb Hd 4870 to a 2gb 4870 X2 and iam seeing lower performance in game's iam running CCC 10.9 as i need it for the HD scaling options wont work on 10.5a
okay to start with i was having problems with the clock's on diffrent gpu's regarding memory and clock speeds but i have installed ATI Tray Tool's and iam forcing the clock's for 2D mode which is 600/400 [GPU/MEM] @1.000v and in 3D mode 775/[email protected] and i have checked in gpu-z that both the gpu's are running at full speed and working
i think my problem lies with the rest off my rig which are as follows
Zalman Z 7 Plus With 4x server grade fan's 2 front 2 side
E5300 @ 3.5
Asus Rampage Formula x48
2x2gb 1066mhz corsair dominators
Zalman CNP9700
2gb His HD4870X2
Thermaltake Toughpower 650w
i think it is my cpu which is bottle necking the system but my understanding of a bottle neck is where one part off the system can not achieve any high so why have i seen a drop in FPS is this due to it being a multi gpu card ? the benchmarks i have run are farcry2 and all the just cause one's
far cry 2 went form 46FPS with the 4870 512mb to 40FPS on the 4870 X2
all setting where maximum @1920x1080 with no AA
just cause 2 went from 37 to 27
mainly high settings @1920x1080 no AA 2xAF
is there some thing wrong with my card ? does forcing the clocks with ATT not work ? or is it just my cpu which iam finding a bit hard to belive as i should be atleast gaining a couple off fps shouldnt i ?
Edit: can one off the dons please correct my title please
E5300 @ 3.5
Zalman CNP9700
2gb His HD4870X2
