Updated panel PWM frequency
3 Nov 2005
Stoke-on-Trent
I have an asus 900 eee PC. There is a new BIOS out for it v0501.
The update contains "Updated panel PWM frequency"
What is this?
Cheers
Thanks or the reply.
Does anyone know what this chages? After hours of searching all I can find is that the new BIOS removes the CPU options (Performance/Power save)
Currently in Performance the CPU runs at 900Mhz and at 630Mhz in powerssave mode.
Found some info for thosse who are interested
- no more porformance/powersave from bios
- runs at 900Mhz on external power and 630Mhz on battery ( eeectl still works )
- brightness levels scaled up a bit
- screen whine is gone
So it lloks like the PWM fixes the screen whine.
Thanks for the pointer nokinidea
