Upgrade a part for better graphics
18 Aug 2009
I would like to upgrade a part of this old system so that videos are a lot smoother as at the moment playing a youtube video is really skippy like almost unwatchable and HQ videos play about one frame every 3 seconds (im not joking). Currently using Windows Vista 64bit. So what would you recommend I upgrade to sort this problem out am looking to spend as little as possible and no im not going to get anything else for the computer or completely upgrade my whole system as it is used for basic purposes. Also all my drivers are up to date so that is not the problem.
Processor: AMD Athlon 64 3500+ 2217MHz
Motherboard: ASUS A8N-SLI
Power Supply: 650W (Not sure what it is)
Memory: Corsair Value Select 1GB DDR RAM 200MHz
Samsung M3 256mb DDR RAM 133MHz
GPU: ATI Radeon X850 XT Platinum 256MB
Your opinions and recommendations.
Websites can be from anywhere really (UK) as long as they are well known and trusted.
Thanks
There should be no problems with your hardwear mate when it comes to playing Youtube Videos. Sounds more like a software issue to me.
However, if you really must upgrade your computer then replacing the processor for say an AMD Athlon X2 4400 (if you can find one) would be good.
This
But you really should consider selling you old bits & buying newer tech.
s939 stuff has held is vaule well
so you could basicly swap your cpu mobo & ram for something much better for next to nothing.
eg basic 775 mobo + an e**** seris cpu + 2gb of ddr2
i appreciate the responses from you fastwunz and pwndirect.
as i said in my original post i am not doing anything else to it. it is being used to surf the internet and receive emails to replace a failed computer so it really just needs to work but would be nice if i could actually watch videos without it being so unclear.
My brother is using the same cpu as you but runs on win xp. He has absolutely no problem watching videos on Youtube. Your parts seems fine to me. I suspect software issues, not hardware.
Has it always been like that? or was it fine before? I would suggest installing the latest adobe flash player if you haven't done so already. See how that goes. Paying for hardware upgrades should be your last option as it is the costliest way for a fix.
sounds more like a software issue. what kind of anti-virus stuff are you using? as ive seen it before where theres an unknown application running in the background and causing the whole system to be slow, be it a virus or some other application
pakjai thanks for the advice. i installed the latest version of Adobe Flash Player and it made it faster but id say 1 frame per 1/2 second for HQ which is a good improvement but still its something else.
Vardy i am using AVG Anti Virus Pro 8.5 and is up-to-date have just gone through msconfig and disabled quite a few things that were unnecessary programs am going to restart now and see if it improves.
once again appreciate the responses
Again I would say software issue your running vista 64bit on an older system, which as we know is a RAM hog. Have you tried a less demanding OS?
after closing un-needed programs in msconfig and restarting my computer i can now play youtube videos in HQ. this is completely my fault i recently reinstalled Vista and didnt bother checking out msconfig after installing numerous programs.
Thanks everyone for the advice looks like il be saving a few quid now.
Cant wait until next year when i build my new computer, will definitely use these forums with the great responses.
Cheers
