Hi guys,
I’m looking to upgrade from my current gaming setup which uses a 1080ti, over to something I hope can give me ray tracing at 4k with decent frame rates (not much to ask for I know).
I play games that are pretty demanding like Cyberpunk, Starfield, Sons of the Forest, Bannerlord etc. and would want at least a consistent 60fps if possible.
I don’t have experience building my own pc so I’m naturally looking at pre-built options like these:
https://www.overclockers.co.uk/ocuk...kf-geforce-rtx-4080-pro-gaming-fs-1el-og.html
https://www.overclockers.co.uk/refract-gaming-indigo-1440p-4k-pro-pre-built-gaming-pc-fs-1dn-ep.html
I would say these are at the top end of my budget, hence why I’m not looking at 4090 options.
I would appreciate some advice on which of the two options above would give me the best performance for my use case, or if there are alternatives you would recommend.
I am open to building my own if it saves a substantial amount of money, but it’s not my preference.
Appreciate your help!
Ben
Ben
