Upgrade advice (Fairly old machine).
9 Feb 2009
Uk
Hi Guys
I have been planning an upgrade of my machine for sometime now. But could generally do it on my own, I just need some options on certain decisions.
Current PC
Intel Core i7 920 D0 Stepping (SLBEJ) 2.66GHz (Nehalem) (Socket LGA1366) -
Zalman CNPS9900-NT CPU Cooler (Socket 754/939/940/AM2/775/1155/1156/1366)
Asus Rampage II Extreme Intel X58 (Socket 1366) DDR3 Motherboard
Corsair Memory Dominator GT 3x2GB DDR3 1866 Mhz(lost a stick )
XFX Geforce 260gtx
Corsair HX 850W ATX Modular SLI Compliant (CMPSU-850HXUK)
OCZ Vertex 2 SSD "32gb"
700gb internal HD (cant remember it).
What I am looking for
1.Case - Looking at the Corsair 600T. Looks really nice and heard nothing but good things. Pretty much decision made.
2.Cooling - Want a silent pc, not really gonna OC that much but would prefer an almost silent CPU cooler.(Suggestions).
3. Graphics - I want to get a decent card. Looking at the 580s at the moment, particularly the Phantom gainward (3gb vram.....)
Any and all input is welcomed, my budget is about £500-£700 pounds as I was planning on keeping certain parts. If you recommend more upgrades and they are backed up by good reasoning I will increase my budget if I am convinced but £500-£700 is flexible.
do you use anything that might make more use of some extra memory ?
are you happy with your ssd, or would a bigger one be more useful, depends what apps etc you would run off it.
have a look at the corsair/antec kuhler enclosed water coolers:
http://www.overclockers.co.uk/productlist.php?groupid=701&catid=57&subid=2262&sortby=priceAsc
graphics card wise if your thinking of the 580, also have a look at the ati 7950.
for the top end of your budget have a look at the nvidia 680/ati 7970.
really depends what your looking to get out of the graphics card the 580/7950 should be more than enough for most things.
what sort of apps you planning to use with it, single/dual/triple displays, what sort of resolution are you thinking of running at etc.....
