Upgrade advice?
Personally I'd say push out for a Sapphire 7850 instead of the 560 if you can afford it. Your PSU should be fine.
Definately look at upgrading to W7, or wait until W8 is out in october (I think?) and get that, vista is horrible..
A RAM upgrade would be great, although 4GB is just about enough atm, yours is very slow. 8GB of 1600MhZ RAM will be great for now and last a while, and be cheap to expand on.
depends on what you class sufficient as. For general usage/mid settings, it should be fine. But, as you said you want to run BF3 on max, I would say, if you can afford it, definately upgrade to an i5 aswell, you would benefit a lot from it.
As for the RAM upgrade, the MhZ is basically the speed, so the 1600MhZ would basically be 3 times faster, and would speed up all processes a lot :)
stupid reply. ;p
you cant put ddr3 ram on a ddr2 board...lol
@ OP: what does modest budget mean? how much $$$ is it?
YOUR BASKET
1 x Sapphire HD 7850 2048MB GDDR5 PCI-Express Graphics Card w/ Nexuiz & Dirt Showdown PC Games £173.99
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - OEM £169.99
1 x Samsung 128GB SSD 830 Desktop Series SATA 6Gb/s Solid State Drive - (MZ-7PC128B/WW) £79.99
1 x Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard £78.98
1 x GeIL Dragon 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (GD38GB1600C11DC) £39.95
Total : £554.30 (includes shipping : £9.50).
If you can afford another £43 for a SSD. Went OEM CPU as you say you have water cooling already. Same as retail minus the heat sink and less warranty which shouldn't be a problem.
Hes not running at 1080P, also the 7850 is better than the 570 since its got 2GB VRAM which is very handy for BF3 and because of its overclockability. I wouldn't wait for 660 since its almost definetley going to cost £200+
is this even true?
i mean i dont play bf3 but from friends who have/do they say nvidia runs it nicer, also if he plays at low res vram isnt going to do much?
If Nvidia cards are better on BF3 it's probably just because they're more powerful in general than the ones being compared to from AMD.
A single 7850 will run BF3 on Ultra easily at the resolutions 19" monitors put out, even a 1GB GTX 460 or 6850 could probably run it on Ultra at low resolutions.
Also BF3 likes 8GB of ram, so if you decide on a new build that would be the ideal amount.
