Upgrade advice
If it were me, I'd probably get the £179 Asus strix 970.
But the 480 is similar performance and a newer card.
Both will do great at 1080 for quite some time.
1060 is £194 right now (EVGA) and thats a pretty solid bet over the 970.
I didn't see that.
In that case, unless the OP really wants to scrimp a few quid, the evga 1060 is probably the better buy.
But really, there's not much performance difference between the 1060, 970 and 480.
I didn't see that.
That's the 3GB 1060 though.....should that really be considered over a 480?
As above in a blind test there isn't really a visible difference between the 480 and 1060. The 480 is capable of getting a lovely boost in Vulkan though and I believe AMD cards age better.
Wouldn't be getting a new 970 today to save £20 quid personally. I had one before the vram scandal and it was ok at 1080p, but it's not clever to buy older architecture NVIDIA cards new for the equivalent of a few rounds savings on the current architecture chips.
Also wouldn't touch a 3GB 1060 with a barge pole for the same price as a 480. Has short lifespan written all over it.
