- 7 May 2017
Hi, I am looking to enter the realm of 1440p gaming and need some advice to whether my pc will handle it and if not what additions i should get. Overall I did not want to spend more than around £500 if i can get away with it.
CPU: AMD Ryzen 5 Quad Core 1500X 3.70GHz
GPU: Radeon RX 580 8gb
Motherboard: ASRock AB350M
memory: Corsair Vengence DDR4 16gb 3000mhz
storage: WD Black PCIe NVMe 256GB SSD
Storage 2: Samsung 500gb ssd
monitor: Acer KG251Qbmiix
PSU: EVGA 500W 80 Plus Power Supply
This is what i had in mind for the CPU and GPU:
My basket at Overclockers UK:
I was looking at maybe putting a bit more into the GPU and going for a 5700 but ive heard they can be really noisy?
I'm not sure if 32gb of RAM is needed but if i had to I would need to upgrade the motherboard too unless i wanted to buy 2 x 16gb kit.
would also need a new monitor: I was thinking of getting this when it comes back in stock
- 1 x AMD Ryzen 5 3600 Six Core 4.2GHz (Socket AM4) Processor - Retail= £199.99
- 1 x Gigabyte GeForce GTX 1660 SUPER Gaming OC 6144MB GDDR6 PCI-Express Graphics Card= £289.99
