Upgrade Advice
When playing games it would be very hard to tell the difference between a 5900x and 5800x. Unless you are doing professional tasks that need the extra cores the only reason to have 5900x for games is to inflate your epeen. Yes my epeen needed inflating I guess but I did not have a budget to stick too.
You will not be disappointed if you go with a 5800x.
Thanks man probably going to go with the 5800x only extra task that may be running are a streaming programme or playing a video on another monitor so it should be good
unless your actually upgrading the GPU right now then I'd still go with that B-grade 3600 then get a 3D V-cache version of the 5000 series which are releasing at the end of the year and will offer another 15% more gaming performance according to AMD
I've used both 5800X and 3600 with an RTX 3080 which is 2x the performance of a 1660 super and as you can see its not night and day in a modern AAA title like watchdogs legion.
