Hi All,
I have had my trusty D2000 for over 5 years and it's time to put them to bed and get something new as they are now very very worn out! My use of these will be via my PC (with external dac/ amp). I have my N5005 for when i'm out and about.
My listening preferences are quite broad but can say I very much like the fundamental sound of the D2000, particular the bass (and mine have been un-modded). And also the fit/ comfort. I am looking for a decent upgrade, don't really have a budget so any suggestions would be appreciated. Closed or semi-closed is a must as excessive sound leakage would be a problem. Quick look on-line suggests these might be work a look:
Denon AH 7200
SONY MDR-Z7
SONY MDR-Z7M2
I would also consider the SONY MDR-Z1R if they really are worth the price premium but these look to be in short supply at the moment, or maybe discontinued.
Thanks.
Denon AH 7200
SONY MDR-Z7
SONY MDR-Z7M2
Thanks.
