- 6 Jan 2011
- Stoke on Trent
Hi Im just shopping around for a second hand q6600 for my daughters motherboard 775 socket. she currently is using a e3300 celeron.
First can I use the same heatsink and fan? Im pretty sure they will fit , but unsure of the heat differential, should I need to get more powerful heatsink fan ect.
Secondly without wanting to hijack another thread below which seems similar issues. Is this the best proccessor to look for for the 775 socket ? Should I be looking at the higher end duel cores ?
For example her gaming is outgrowing the less demanding games like sims and moving to racedriver grid.
For example on racedriver grid cant do more than half a lap without getting kicked, online or LAN. network is fine no issues with our bigger pc. just think the weakest link is the celeron.
Any help would be app thanks all
