- 23 Aug 2007
Hay all.
Right i am getting 5850 and OCZ ModXStream Pro 600w Silent SLI Certified Modular Power Supply on the 27th this month
And about 2 weeks later i will be upgrading the rest of the pc.
I was thinking this.
I am not sure if the ram i picked will work with the motherboard and if the cpu cooler will fit ok with that ram as it looks like it will stick out a bit.
Anything that don't look good or should i change ?
My case is aeroview CoolView case
Thanks for any advice
