Upgrade from 939 system
Decided to go down MM route and just picked up a Gigabyte GA-P35C-DS3r motherboard, now my next question is what would be a cheap socket 775 processor to look out for that will be quicker than the opteron I currently have?
Also what memory route would you guys recommend to look out for DDR3 or 2, am thinking of 4gb?
regards,
Matt
Hi Matt,
I would check out:
http://www.tomshardware.co.uk/best-gaming-cpu,review-31666-6.html
Gives you a CPU performance hierarchy chart (for gaming anyway)...
Good budget LGA775 CPU:
http://www.overclockers.co.uk/showproduct.php?prodid=CP-273-IN&groupid=701&catid=6&subcat=793
Does good stuff especially if OC. This would definitely be faster then your Opteron.
I would have thought DDR2 still - it can be picked up for a song and would be a better match for a Core 2 CPU. DDR3 would surely be best bought alongside your shiny new Core i7 920 CPU not in the prospect of some future upgrade at a later date...
4Gb RAM would be good - unless you start doing Virtualisation work, etc... :D
Bob
guys is this mobo any gud "MSI 790FX-GD70 AMD 790FX " as compared to Asus crosshair III and M4.... deluxe version ,m talking in evry aspect?
overclocking , GPU capacity, power phase, PCI-e slots, well its specs shows that its better thn other two ASUS mobos, and ts supoorts 2100mhz ram aswell :)
Hhhmm... you posting in the wrong thread bud or just hijacking ???!! :o
