I would avoid the piledriver CPU's and go straight for an I3 being £23 cheaper while on sale, also leaves you with option to upgrade to an I5 when funds allow at a later date.
What stulid suggested would be best.
There is always the FX-8 or potential future AMD chips on the AM3+ socket as well though.Do the i3's whip q6600 in terms of performance ?
i have same mobo and cpu as the op, ecept i have a 8800gtx 768mb instead of his 6950
if he was gunan stretch his budget to them best of just buying componants and building then overclocking himself
YOUR BASKET
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £184.99
1 x Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard £81.98
1 x Xigmatek Dark Knight SD-1283 Night Hawk Edition CPU Cooler (Socket LGA 2011/1366/1156/1155/775 and AMD FM1/AM3/AM2+/AM2) £34.99
1 x Corsair XMS3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX8GX3M2A1600C9) £29.99
Total : £343.36 (includes shipping : £9.50).
CPU cooler can be swapped for another if wanted / needed.
Personally I would choose a different board (purely for aesthetic reasons) though that board does have good reviews and high praise for the price.Im looking to upgrade and like you said acme15, i wouldnt do it for any less than a 3570k
Could the OP stretch his budget to these ?
http://www.overclockers.co.uk/showproduct.php?prodid=BU-110-OE&groupid=43&catid=2384&subcat=2288
http://www.overclockers.co.uk/showproduct.php?prodid=BU-112-OE&groupid=43&catid=2384&subcat=2288
