upgrade help needed
21 Feb 2007
hi, havent been on here in a while but its upgrade time.
i have specced the following, i already have everything else needed its just ram, gpu, mobo and cpu that needs upgrading. £250 is my budget, is there anything that i should change for better performance(i do lots of avid, photoshop work and occasional gaming)
i will be overclocking!
**B Grade** Gigabyte GA-P35-DS3L Intel P35 (Socket 775) PCI-Express DDR2 (MB-100-GI) £39.99 (£46.99)
Intel Core 2 Duo E8200 LGA775 'Wolfdale' 2.66GHz (1333FSB) - Retail £99.99 (£117.49)
OcUK GeForce 8600 GT 256MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail £41.99 (£49.34)
OCZ 2GB (2x1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC Series DDR2 (OCZ2P800R22GK) £20.99 (£24.66)
Total : £248.17
thanks
jake
Looks good if you don't play the latest games. But if you do I'd advise getting a E2180 and use the spare cash towards a 3850pro 512Mb or 9600GT.
Yeah, the only thing to consider is can you stretch to better graphics card, or swap the cpu to save the money there.
