Upgrade help please...
26 Jun 2004
Leeds
It is finally time for me to upgrade my PC.
Current PC is XP2700, 1gb ram ASUS mobo, 9800XT, Audigy ZS 2.
I will at some point want to try and overclock the new system (never done it before and am interested) please bear that in mind.
CPU and RAM chose below:
Corsair 2GB DDR XMS3200C2PT TwinX (2x1GB) CAS2 (MY-079-CS)
AMD Athlon 64 X2 Dual Core 3800+ (Socket 939) - OEM (CP-152-AM)
As for the motherboard / Cooler / GFX card I would like some opinions please...
I think very highly of Asus boards and would definately buy another one, however which one I am unsure. Is the A8N Premium worth the extra cash over the SE version? Does the motherboard have a big influence in overclocks?
Would a Thermalright XP/SI 120 fit the A8N's? I hear these are one of the best coolers around.
Finally onto the GFX card, I was thinking about pushing the boat out and purchasing a 7900GT. Good choice or...?
I will be keeping my sound card and hard drives from my current PC, also my PSU which is a hyperpower 420w. I can't see me needing a more powerful one?
Thanks for reading
You won't be able to overclock very well with an Asus board, they're more known for reliability. Abit, DFI and MSI are better overclockers. The 3800+ X2 is a good choice for an overclocking CPU, some people can hit 2.5/6GHz. I would go for these:
MSI K8N Neo4 Platinum nForce4 Ultra (Socket 939) PCI-Express Motherboard
HIS Excalibur ATI Radeon X1900 XT-X 512MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail
Arctic Cooling Freezer 64 Pro CPU Cooler (Socket 754/939/940)
Thanks for the reply, much appreciated.
I have just had a read of the **Official Asus A8N-SLI Premium Thread** and people in there have had some reasonable results on overclocking. Also some people are using the thermalright coolers on the same motherboard.
I think I will stick with ASUS as reliablity and stability is probably more important.
The ATI Radeon X1900 XT-X is probably more than I would like to spend on a grahpics card, what are the X1800's like? Much better than the 7900GT's?
Cheers
Ok that's fair, yeah I think the X1800XT's are about the same as the 7900GT's. If you play games at high resolutions and/or AA&AF, then splash out for the 512MB one.
The X2 3800+ is a great CPU.
As for graphics the X1800XT is slightly faster than the 7900GT. The X1800XT 512MB is a great buy as more & more games are likely going to need the 512MB ram to run at full settings.
Yep, go for the 512Mb :)
