The fans can be connected with one of these if you run out of motherboard connectors.
Also, the PWR_FAN and CHIP_FAN connectors are both for connecting fans to. I assume that CHIP_FAN is for a north/south brige chip cooler, and that the motherboard designers got their English a little skewed and wrote "PWR_FAN" instead of "FAN_PWR"
Speaking of which, where is the CHIP_FAn connector? I only see "PWR_FAN" and "CHA_FAN1".
Ah right, so I plug that into a connector from the PSU then connect fans to it? Nice, thanks Ucof.
The CHIP_FAN connector is on my current board, the A8N-SLi, which has the NVIDIA nForce4 SLi plugged into it. Current board also has 2x CHA_FAN for the case fans.
I'm guessing the PWR_FAN and CHA_FAN labelled on the M3A78 are for the case fans maybe, as it doesn't seem to have any chip fans on the board itself like the A8N-SLi?
Owwww soo confused at this point
I'll be sticking with XP, so I'm just wondering now whether to go for the 4GB memory or stay with 2GB. I understand the may as well get 4GB cos of the price, but I just want to make sure, will XP will only use 3GB or whatever its max memory is and ignore the rest or could the extra memory cause any problems?
Sorry all for sooo many questions, but I messed up with the Blu-ray player and not having a good enough rig, but theres a big difference from £78 to £500+ i can't afford to get it wrong
