Upgrade help please
25 Oct 2004
Hey there guys. PC recently died, and im as yet to find the cause of the problem. Anyway, just got back from holiday and have also shot around 8 hours worth of high def footage which needs editing. My PC has really struggled in the past with this. So, im thinking of upgrading. my suspicions lie with the mobo as the cause of the recent death of my pc
Im currently running
e6600 clocked at 3.6ghz
4gb geil ultra low latency 6400 ram
evga 680i mobo
nvidia 8800gts 512mb
bfg 1000w psu
antec 900 case
im def going to have to get a new motherboard, and if im going to stick with my current processor im not going to have much in the way of choice
Im really not that bothered about gaming anymore. Just want a fast setup with quick load times thats not going to struggle too much with hd editing. Do you think id benefit from a new cpu aswell
Im basically after the biggest performance gain for minimal cost. I
Appreciate any help you can offer guys
Thanks
someone must have some suggestions guys. As you can see from the spec in my first post, its been a long time since i dabbled in pc components
Can someone please recommend a processor, ram, mobo combo for me. Like i said, its been a while since i even looked at componenets. My budget is around 400 but id like to spend less if possible. Appreicate any help
This is bout your best Intel bet
Intel Core i5 750 2.66GHz (Lynnfield) (Socket LGA1156) - Retail £167.99 (£142.97)
Gigabyte GA-P55A-UD3R Intel P55 (Socket 1156) DDR3 Motherboard £133.99 (£114.03)
OCZ Gold 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (OCZ3G1600LV4GK) £89.99 (£76.59)
Total: £391.97
Or AMD, which is prob bit better overall tbh
AMD Phenom II X6 Six Core 1090T Black Edition 3.20GHz (Socket AM3) - Retail £236.99 (£201.69)
Gigabyte GA-880GM-UD2H AMD 880G (Socket AM3) microATX DDR3 Motherboard £72.99 (£62.12)
Total: £399.97
