Hi all,
Been a while since I've posted or kept up-to-date with builds, so was hoping for some help please.
Current system is 2500k (weak 4.2ghz oc, as using a low-end mobo), 1060 3gb, 16gb 1600 ram, 650w seasonic gold rated psu, 250gb sata III ssd, 3tb hdd.
Looking to increase FPS for MMORPG's (Bless online coming soon), specifically the minimum FPS in highly populated areas. I don't care about running on the highest gfx settings, but do need to have the view range set to max. My monitor is a Dell Ultrasharp at 1440p 60hz.
Not looking to spend more than needed, but would like to future proof things.
Currently thinking to upgrade to something like the following:
CPU - 8700k (I believe most mmo's are CPU bound and that the hyperthreading should help raise the minimum fps, but could be worth saving some money and getting the 8600k?)
Mobo - Gigabyte Aorus Z370 Gaming K3
RAM - 16GB 3000/3200 mhz with ok'ish timings.
SSD - Samsung 960 EVO 250GB
Cooler - Be Quiet Dark Rock Pro 3 (with the aim of clocking the i7/i5 to 4.9ghz)
Reusing my 1060 3gb, 650w psu etc.
Thanks for looking
Thanks for looking
