Upgrade Help
23 Aug 2007
Rothesay
I have been wanting to upgrade my main system for some time now, and have recently come into to a small amount of money which will finally allow me to do so.
I have been an AMD user for some time now mainly due to the cost and being honest i find they usually handle what i want them to do.
I do use my system mainly for SWTOR online at present but do play a few other games.
Currently my main pc is built around an AMD Phenomm 940 with 4 gig ddr2 ram and did have an AMD 5870 in it till the psu died a couple of months back.
I currently have a brand new Corsair TX650 waiting to go in and have recently aquired a 6950 which i mangaged to fully unlock to a 6970 which is in my back up system.
Cooling wise my main system is WC using a D4 pump, res and a Thermochill PA 480 as well as an EK Supreme WB so this will stay and be transposed to the new system all housed in a Lian-Li A20 which i have modified slightly.
Here is what ive chosen so far
http://i286.photobucket.com/albums/ll104/sirlesmp/basket-4.jpg
Now i have heard/read rumors that the Amd Piledriver chips should be released sometime this week coming and was wondering if i should wait a little and see and swap out the cpu for one of the new ones when they do.
The memory and SSD's can and probably will be swapped out for ones that feature on the This weeks offer if i can find better for the same price or less.
The Game pad is to replace a yber Snipa flexiglow which is showing its age ( i just hope i can get used to the new one)
I'm hoping to process the order on wednesday and will of course be looking at OC which ever cpu i do get so any help with the componets ive chosen or slightly better for arround the same price would be nice.
Im not obversed to intel but looking at current prices i dont think i can afford a system based around them which will give better performance at the the current £500 or so ive set my budget at.
I could save myself £140 by using the AMD Phenom II X6 1090T in my back up system but as that system is running just fine i do not whish to mess with it in any other way than by changing over the new 6950 for my old 5870. It would also mean i would have to chosse slower DDR3 which in turn would also save me a few extra £'s
yes it is but overclocking has been fruitless, as even a small clock of 2-3 hundred Mhz made the system unstable
and after the psu went im not 100% sure the cpu is still working, although in saying that the gpu and memory do still work as i have tested them in my back up system.
how well would this lot overclock on watercooling as i have the wc in the case already all i would have to do to it would be change the mont to the cpu waterblock
oops how did i miss the watercooled part, no need for separate heatsink & fan.
So that brings the price down a bit more, you could even swap out the two Kingston hyperX 120GB for a single Samsung 256 drive.
YOUR BASKET
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - OEM £179.99
1 x Samsung 256GB SSD 830 Series SATA 6Gb/s Solid State Drive - (MZ-7PC256B/WW) £149.99
1 x Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard £83.99
1 x Razer Nostromo Gaming Keypad £54.98
1 x GeIL Black Dragon 16GB (2x8GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (GD316GB1600C11DC) **OcUK Exclusive** £47.99
Total : £516.94 (includes shipping : FREE).
YOUR BASKET
Gets my vote - with the single 256GB drive.
the reason i was lloking at the 2 drives was for Raid 0
the only thing i would be worried about with the intel side is putting the cpu into the mobo as the mobo has the pins these days on them.
I really wouldn't about that. Intel currently offer the superior CPU as far as performance goes.
As said above you really don't need to worry about that, and even if you did somehow get an issue the motherboards are cheaper to replace than the processor's
OK i must ask now that the Amd Piledriver cpu @4ghz is availeable at £170 and the supposed improvmensts they have made on the bulldozer version is going for an AMD 8 core over an known intel quad core that will clock to 4.4ghz worth it for gaming/multitasking
The 3570K is still the better CPU.
