Upgrade help
bbK
bbK
12 Dec 2003
wales
OK so just having got back from i52 LAN and having to carry this case from the car park to the arena it is clear i need to move this PC into a new mini itx build. So i am wondering if anyone would give me help in doing so.
Current spec:
Cooler Master HAF-X
Asrock Z68 Extreme4 Gen3
i5 2500k
h100 cooler
16GB Corsair Vengeance
250gb SSD
Gigabyte ATI Radeon HD 7970
Corsair 850w PSU
I know i need to upgrade the motherboard, not sure if the card/psu will fit in a small case etc and that's where im hoping someone could spec me something up. I've had a quick look at the cases and the Corsair Carbide looks quite good... any thoughts on that?
Upgrade wise I would like to keep the cost around 300-400 but if i have to pay more i will.
Cheers for the suggestions. I've just realised that the case is on pre-order until late September tho.... hmmmz
That's a mATX case not an ITX case. My go-to recommendation for ITX and transportability is the Shuttle XPC range. They work best if your GPU has a blower fan.
You won't be able to fit the H100 cooler inside the Shuttle, but Asetek do a 92mm liquid cooler.
The air240 takes mini-itx boards as well.
It did cross my mind to get a 2nd hand mobo 'cos i only play CSGO and it is a perfectly fine setup for that. I'll have a look around.
As Lee32uk mentioned it can take a ITX board along with the op's AIO, this will be smaller than his current setup.
