Upgrade MB
Any mid-range mobo will do
As it stands the 7800x3d is so power efficient that it'll run even on mobos with potato vrms.
(Hopefully the 9800x3d will be similar)
I have ryzen 7700 non x but has slow boot , and i have Gigabyte B650 gaming x ax v1.2 and not has support for ryzen 9000 series ... and i want to change MB for start and best price performance i see Gigabyte X870E Aorus Elite .....
And i saw many people say to avoid Gigabyte MB ....
Budget 700 euro max for MB and Cpu
I will use mostly for gaming
Ok , i want to change MB for the future upgrades not only cpu , also for more usb ports and pcie 5 and better vrm because i have a lots usb gadgets , keyboard only has 2 usb, and want for spdif , i have a soundbar with spidf and want to connect it , dont want separate sound card for what i need
The X870 board you mentioned looks fine, if you want USB4, but there haven't been many reviews/roundups yet, so if there's a lemon out there we won't know for a few weeks or months.
Dont need speed usb want only more ports :) .. and i saw X670E its with 20 euro cheaper then X870E so i want to want X870E Aorus Elite wifi ... if worth it
