- 6 Sep 2016
Its the correct socket motherboard if that's what you mean but they are pre order so no one has used them yet.
Cutting edge can sometimes have issues on release and need firmware updates to fix bugs; you might be able to find reviews on youtube etc if they sent samples out but no one on here will have used them.
You might also want to change your RAM to something faster / XMP3 someone else might be able to advise.
Do they ship with a CPU cooler, otherwise thats something else to add to the shopping list?
£300 for a mobo plus £380 for a cpu because you want more USB ports and SPDIF does seem a bit steep if you are otherwise happy with your current setup.
A PCIE USB card and external sound card might be another option, or even an old fashoined USB drive bay if it will fit in your case; but I think you have the upgrade itch and just want something shiny which is fine if its what you want its your money at the end of the day.
If you do go with it maybe post some benches / a review as you will be one of the first on the new socket.
The vast vast expensive of £17
AXAGON PCEU-43RS PCIe Adapter 4x USB3.0 UASP VIA, 15-pin SATA Power Controller Card
Order AXAGON PCEU-43RS PCIe Adapter 4x USB3.0 UASP VIA, 15-pin SATA Power Controller Card now online and benefit from fast delivery.
Another model with 7 ports £60 or so.
