So I have a rather old 5.1 package of Mordaunt Short Premiere speakers, which I upgraded the front pair of:-
And this is all working through my Onkyo TX-NR646 amp and I listen to a mix of music and home theatre etc.
Three considerations:-
So after looking around I'm wonder if a Dali Spektor speaker setup might be the answer?
In people's opinion, is that going to give me a good solid noticable improvement in audio quality over my old Mordaunt Short speaker package? Is it going to be £ well spent? ie: My nightmare would be I plug it all in and there's little/no real improvement, as the limitation is the amp, and the Mordaunt Shorts were about the same audio quality etc as any new speakers etc...
There is an alternative of using Q Acoustics 3010i and 3020i? But their sub is definately too big, so I guess I could still use a Dali (or similar) one with it.
Thoughts & advice welcome...
- Front: 902i - https://www.hifix.co.uk/mordaunt-short-avant-902i-speakers
- Rear: 302 - https://www.hifix.co.uk/mordaunt-short-premier-ms302-speakers-pair
- Center: 304 - https://www.hifix.co.uk/mordaunt-short-ms304-centre-speaker-cherry-open-box
- Sub: 308W - https://www.hifix.co.uk/mordaunt-short-premier-ms308w-sub-woofer-vanadium
- The current front 902 speakers are quite deep, with one on a shelf, very very close to the rear of the unit. Not ideal (being rear ported)! If I can replace with a less deep speaker, great!
- I feel the center speaker maybe isn't as good as it could be. It's in a dedicated shelf immediately below the TV, and there's enough room to fit a bigger speaker in there.
- The woofer feels a tad disconnected, if that's a good term. It doesn't feel tied/combined into audio at times, almost like it's not controlled enough?
- Front: Spektor 1 or if really worth while the 2s - The 2s are 3cm less deep than my existing fronts, so would give an inch more of space on that shelf at the rear. The 1s would give loads more rear space, so would be the more logical choice space wise at least.
- Rear: Spektor 1 or keep my MS 302?
- Center: Spektor Vokal (fitting into a dedicated slot under the TV (50cm x 16cm)
- Sub: C-8 D (down firing) or E-9 F (front firing)
