So, i currently have
AMD Piledriver FX-8 Eight Core 8350 Black Edition 4.00GHz (Socket AM3+) Processor
Avexir Core Blue Series 8GB (2x4GB) DDR3 PC3-21000C11 2666MHz Dual Channel Memory Kit (Which i can't find anywhere to go up to 16GB...)
Gigabyte 990FXA-UD5 AMD 990FX (Socket AM3+) DDR3 Motherboard
I'v been offered a Gigabyte GA-Z77X-D3H with an Core i5 3570k but i'm unsure on what to do.
I mostply play CS:GO which is CPU intensive. I know the i5 has the intergrated graphics processing which will help a lot.
So the question is, move over to what has been offered to me or would it be better to just get something more indate. I'v been looking at the AMD APU CPU's. As far as cost goes, i don't mind spending money but i would prefer if i didn't have too as any would.
Yes i know my current mobo dosn't support 2666Mhz RAM and yes it annoys me but ever so little. I currently run two 770GTX's in SLi and have watercooling ready to go in except a CPU block, hence this post to see what i should do pre-ordering a water block.
Thanks for any help in advanced.
no point going newer, things have barely moved on. If it's more money then hard to say what you should do - depends how much you're willing to spend and what your alternatives are.
) I think (It's something thats very close to 4590k but prev gen) get more FPS on max settings, how would you explain that? He also only has a single 770GTX
