Upgrade or new system?
3 Apr 2009
Preston UK
I have a Pentium 3 socket 775 on a ECS P4M800PRO-M2 with 2 gig of ram im using this to run Autocad 2007, Lantek Expert II & sage account software.
At times it runs ok other time it really struggles my question is are there any up grade options or do I need a new system if so please help.
I cant use my signature system because thats my gaming system at home the other is for using at work.
Please keep the ideas coming.
Many thanks
As said just stick in a quadcore Q9550 or if you dont want to spend that much a Q8400. They're socket 775 so you can just swap them out. 2GB ram is enough for CAD 2007 although if you upgrade to 2008/9 or 10 I would recoment 4GB (even though the spec recomends 2 people at work struggle with that much in later versions). GPU isn't an issue as CAD doesnt use it so onboard graphics are fine.
If you really must upgrade the system completely, something like this should be good and fairly cheap:
AMD Phenom II X4 Quad Core 940 Black Edition 3.0GHz (Socket AM2+) - Retail £143.99
(£125.21) £143.99
(£125.21)
Western Digital Caviar Black 500GB SATA-II 32MB Cache - OEM (WD5001AALS) Western Digital Caviar Black 500GB SATA-II 32MB Cache - OEM (WD5001AALS) £46.99
(£40.86) £46.99
(£40.86)
OCZ StealthXStream 400w Silent ATX2 Power Supply OCZ StealthXStream 400w Silent ATX2 Power Supply £42.99
(£37.38) £42.99
(£37.38)
Kingston HyperX 4GB (2x2GB) DDR2 8500C5 1066MHz Dual Channel (KHX8500D2K2/4G) Kingston HyperX 4GB (2x2GB) DDR2 8500C5 1066MHz Dual Channel (KHX8500D2K2/4G) £37.98
(£33.03) £37.98
(£33.03)
Foxconn M61PMV nForce 430 (Socket AM2/AM2+) PCI-Express DDR2 Motherboard Foxconn M61PMV nForce 430 (Socket AM2/AM2+) PCI-Express DDR2 Motherboard £36.79
(£31.99) £36.79
(£31.99)
Titan TTC-NK85TZ Fenrir CPU Cooler (Socket 754/939/940/AM2/LGA775/LGA1366) Titan TTC-NK85TZ Fenrir CPU Cooler (Socket 754/939/940/AM2/LGA775/LGA1366) £33.34
(£28.99) £33.34
(£28.99)
Coolermaster Elite 335 Case - Black (No PSU) Coolermaster Elite 335 Case - Black (No PSU) £28.99
(£25.21) £28.99
(£25.21)
Pioneer DVR-216DBK 20x DVD±RW SATA Dual Layer ReWriter (Black) - OEM Pioneer DVR-216DBK 20x DVD±RW SATA Dual Layer ReWriter (Black) - OEM £17.99
(£15.64) £17.99
(£15.64)
Sub Total : £338.31
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £12.50
VAT is being charged at 15% VAT : £52.62
Total : £403.43
Drop the cooler if you dont plan to overclock.
