Upgrade or not ... ?
9 Jan 2011
Hi guys
For the last few years ive been using a core i5 3330 and 8gb of ddr3 ram ( 1333mhz ) ... combined with that i recently replaced a HD6850 with a significantly better MSI R9 270x 4GB ..
for now im happy with the gpu and ram,however my problem is if i want to upgrade my cpu i would have to ditch the complete motherboard,cpu and ram ( if i go to ddr4 ) and this would be significantly more expensive than simply replacing the cpu
is there any reason why i couldnt keep on using the core i5 3330 and then replace it later on with say a core i7 2600k ( which i can get for £90 second hand )
as it stands im running all games ok and theres no problems,however sooner or later the socket 1155 processor will become a relic,so whats your advice ?
the annoying thing is my second pc also uses socket 1155 ( a core i3 3220,8gb ram and the HD6850 ) .. and im suprised how well that still performs .....
ok its allright for tiny tom logan and linus sebastion to tell us to upgrade to the latest £300 mobo and £500 cpu,however most of us dont have £800 to spend on upgrades and they get engineering samples most of the time that does not cost a penny ....
any feedback will be much appreciated
take care guys and happy xmas !
In your position I would sell my current CPU and buy a second hand upgrade like an i5-3570k/2500k or an i7-2600k.
They would all serve you pretty well, you will see a noticeable difference is many games and those CPUs will last for a fairly long time.
The difference between them is that the i7 has more cache and is hyperthreaded compared to the 3570k, and the 3570k has a higher clock speed than the 2500k.
I would say they are all worth their money, so it is entirely down to how much you want to spend as to which one to get. They are all good overclockers if you are interested in OCing them as well :)
Thanks frank ... the core i7 2600 is avalible for £95 second hand ... i suppose i could trade in my core i3 and HD6850 ( from spare pc ) and then use the instore voucher towards the i7 2600
then the core i5 3330 can be used with the spare pc along with a GTX460 i have ... thanks mate
So one build will be an i5-3330 + GTX 460 and the main one will be an i7-2600k + R9 270x?
They sounds like good builds to me, the 2600k will have plenty of headroom for a GPU upgrade if you ever want to upgrade for gaming again. The 2600k is a really great CPU :)
