Man of Honour
- 23 Mar 2011
- West Side
So maybe something like this an add in a nvidia rtx 3070 gfx card.
https://www.overclockers.co.uk/checkout/cart
Your basket doesn't show anything.
Yes it would work
Corsair rm 850w £10 more 10 year warranty fully modular, tx 7 year warranty semi modular.
Matx and ATX cases will work but you always have to check size limitations for , coolers , gpu, etc
Further upgrade as I said in a previous post 32gb ram and 3700x.
Then drop in a 3070 boom.
Thanks again micky I apologise for the noob questions. Is there a diffrenece between the 3700x CPU such as the X/XT ect?
Also so questions for the 3070 GFX cards there seems to be quite a few options.
And lastly the cooler I picked is only £25 should I look at a better version or watercooling?
That motherboard WILL NOT FIT in that case, you either need to get a bigger case or Matx motherboard .
RAIJINTEK SILENOS PRO ARGB is a n8ce case
https://www.overclockers.co.uk/raij...ming-case-black-tempered-glass-ca-04d-rt.html
Xt clockeded slightly higher than the x but not worth the cost.
3070 is not released yet you could be waiting a bit so use your old one .
Cooler is perfectly fine the duo version looks nice, you can always spend more.
I followed your advice and this is the new basket. Is there a difference between the b550s as ive just added in any byt there seems to be like 10 different ones.
Also which RTX 3070 would you recommend once there released as there seems to be a few different versions.
I had a look at coolers but couldn't find any that weren't £150 plus
