Hey Guys,
so my current system was bought on the 8th of July 2015 (had to check my order history!
and I added the G-Sync monitor later)the spec is as follows...
Case - NZXT H440 Black/Red
CPU/MOBO - Gigabyte Z97X-Gaming 7 - Devils Canyon Core i7 4790K CPU & Motherboard Bundle
CPU COOL - Arctic Cooling Liquid Freezer AIO CPU Cooler - 240mm
GFX CARD - Gigabyte GeForce GTX 980Ti G1 Gaming 6GB
RAM - TeamGroup Vulcan RED 16GB (2x8GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit
SSD - 1TB Samsung 850 EVO SSD.
M2 SSD - 1TB 970 Evo (Not added to this build atm but is brand new and able to be installed.)
PSU - XFX XTR 850W '80 Plus Gold' Fully Modular Power Supply
-MONITORS-
MAIN MON - Acer Predator XB271HU G-Sync, 165hz, 1440p, IPS
2ND MON - Dell Ultrasharp U2515H 1440p.
Could somebody define me a decent upgrade path? I'm assuming obviously monitors, CPU cooler, SSD's, and case can stay (unless there's a prettier tempered glass one kicking around?) and then maybe CPU/MOBO/RAM would need to be replaced all at once? and then GFX can be upgraded individually?
anybody throw me out some recommendations of a high end card to max out with my system setup, I don't really have any desire for 4K gaming happy at 1440p, games I play can range anything from the new Call of duty, to CS:GO, PUBG, Fortnite, Rainbow Six to higher end AAA titles so I'm really open to suggestion on what you guys think the best upgrade path is or whether you think my system is just fine as is?
I wasn't sure if my GFX card/CPU were getting a little dated being bought 5 years ago?
and I added the G-Sync monitor later)the spec is as follows...Case - NZXT H440 Black/Red
-MONITORS-
